Results 1 to 10 of 18
Thread: WTB: parts from a broken Behr under-dash vent
    Aug 2011
    Eugene, OR
    My '72 came with factory Behr A/C. I plan to put it back in service. One of the 6 under dash vents (part #901-573-067-00) has a couple of needs. Before I start looking for an intact vent, I thought I'd see if anyone has one sitting around that may be broken and/or incomplete, but still have the two pieces I need. The parts I need were definitely used from '69-73, maybe through '75 or '76 as well.
    Here's a shot of what I have and need. I need one of the horizontal spreaders that is intact (mine has the end segment broken off), as well as one of the vertical vanes. Ideally the vane should be one of the four outside vanes, but a center vane would work and the difference is not likely to be noticeable.
    Maybe someone can help?
    - Arne
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    I should have one
    Aug 2011
    Eugene, OR
    I'll send you a PM, Dirk.
    - Arne
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Arne View Post
    if Dirks "should have" turns out to be a "can`t find" this...i also should have this. but corontly shipping to the US is a $$$$ PITA17
    Mar 2016
    U.K.
    Hi Arne,
    If you are looking for a complete vent, I have this one available:
    The unit is in good condition with no cracks or broken bits, just a bit dirty. Most of the silver detailing around the vent remains. This is the only part of the a/c unit I have.
    Shipping would be from the UK.
    Send me a PM with your email and I can send you more photos if you are interested.
    Kind regards
    Gitesh
    Aug 2011
    Eugene, OR
    Dirk is checking into this for me now, will keep @moito's in mind as a backup.
    Gitesh, thanks for the offer, but yours is a different style unit and no parts look to be interchangeable.
    - Arne
    Aug 2011
    Eugene, OR
    @dirk07 checked his stash, did not have all of what I need. PM sent to @moito
    - Arne
    Aug 2011
    Eugene, OR
    No word from Franz (moito), so still looking.
    - Arne
    Aug 2011
    Eugene, OR
    Not a super high priority, but still looking.
    - Arne
    Dec 2003
    West Los Angeles
    Guys, this is a perfect example of a good use of a 3D printer. Must be someone here who can scan or model these parts. They are often broken on early a/c diffusers.
    techweenie.com
