Thread: 1970 911 Licence Plate Braket
    Junior Member
    Apr 2020
    Hi Everyone. New to the forum. Please forgive the Newbie Question. Just bought a wonderful 1970 911S Targa. Previous owner had rear plate mounted directly to the body of the car in an inexpensive chrome frame. I am looking for something that will protect the car and that may have even come with the car originally. right now there are the 4 original holes in the body that line right up with a plate. in each of them is a rather tired plastic Molly. The the only brackets I see listed would require two new holes which is not happening.
    Anyone have a nice clean solution? One that may even be "correct" for the car?
    Thank you all in advance.
    James
    Dec 2010
    Southold, NY
    If the existing holes agree with the plates, perhaps replace the the plastic fasteners with metal rivet nuts that will accept machine screws. Attractive backing for license plate is easy to fashion from aluminum plate. Metal or plastic washers may be used to space license plate away from car body.
    May 2014
    South East USA
    If you send a photo. It will do a lot more.
    Touch the icon of the frame, with a tiny tree in it. That's too add a photo.
    Plus. We want to see your car.
    Sep 2012
    Colorado
    Your “not happening” solution is what is correct for the car, not what the PO did. The bracket mounts to the car via 2 holes, the plate mounts to the bracket, and the frame mounts to the plate, not to the car. The 2 holes would be correct; the 4 holes are not correct. Which suggests the rear panel maybe was replaced at some point?
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    Jun 2012
    London, Ontario, Canada
    It’s up to you, but as noted, the two hole bracket is the correct one. Normally held on by two nuts and bolts, but you could use rivet nuts or just rivets so you don’t have to disassemble the panel. Your plate should cover the existing holes or you can push in 4 plastic hole caps to fill and finish them a bit more.
    Ravi
    Early 911S Registry # 2395
