car is a '66 and my setup requires 15mm spacers @ the rear. I bought a set of H&R. beautiful product but they require replacement of the standard studs. the only other type I've seen so far is Sparco. are there others ? feedback appreciated.
1940 Mercury town sedan
@LiveFromNY thanks guy, but those require the replacement of the existing studs, an option that may not be possible or practical.
https://www.early911sregistry.org/fo...ar-wheel-studs
Any deviation from steel wheels and no spacer is going to require longer studs. You have 35mm studs (dates back to 356 days) and they just aren't long enough. Replacing studs is not a difficult job as long as you have a BFH and some spare time.
Jim
thanks Jim... D.B. and I gave this a shot yesterday, but came up short. I'm gonna tray again after removing the E-brake adjuster and "addressing" a stock stud. not sure I'll be able sneak a new 70mm stud back in.
even with 10mm spacers you do need to replace the studs... and yes, as written before, easy to be done...
but allow:
if you go with 15mm in the back...
a. what you do with the front?
b. what are you aiming at?
br
haul
59 750 pre unit triton
65 912 slate gray "erwin"
73 914 ravennagreen "ferdl"
erwin_loves_polo
Pretty sure we did by removing the handbrake cable and butterfly actuators, then line up stud with cable hole.
something like this would have been plan B if the stud swap had not worked out.
the complete process is outlined here;
https://www.early911sregistry.org/fo...-hub-stud-swap
