Results 1 to 2 of 2
Thread: Gear ratio info needed 1968 911T and 911L
    I'm updating my 911 Authenticity book and including chapters on the major mechanical items! I've been fighting with the gearbox types for the past week or two. I am pretty much satisfied with the list I have -- though there are many that have no actual end numbers, which is okay -- I guess.
    For 1968, I need to know the gear sets for the 911T and 911L. The 4-speed 911T is A/HB/S/Z. I do not know the 901/03 911T 5-speed. The 902/0 4-speed 911L may be A/H/Q/X, but I don't know for sure. I am confused about the 911L 5-speed -- is it a 902/1 or a 902/01? Serial numbers are 3280001- Don't know the gear sets. If you can help or recommend a really great gearbox guy to proof my text, please let me know here or at: 356drb@indy.net.
    Thanks and here are the gear ratio codes:
    901 Transmission Ratios
    First Gear Sets
    A 11:34 3.091
    AA 12.34 2.833
    B 14:37 2.643
    C 15:36 2.400
    Second Gear Sets
    E 17:34 2.000
    F 18:34 1.667
    GA 18:32 1.778
    H 19:32 1.684
    HA 20:32 1.600
    HB 19:31 1.632
    I 20:31 1.550
    Third/Fourth/Fifth Gear Sets
    I 20:31 1.550
    J 21:31 1.476
    M 22:29 1.318
    O 23:28 1.217
    Q 24:27 1.125
    R 25:27 1.080
    S 25:26 1.040
    T 26:26 1.000
    U 26:25 0.962
    V 27:25 0.926
    X 28:24 0.857
    Y 28:23 0.821
    Z 29:23 0.793
    ZA 29:22 0.759
    Quote Originally Posted by Brett Johnson View Post
    Brett, here's a factory chart published in Sept 67, at the introduction of the 68 model year.
    It's a bit easier to read than the chart in the Technical Specs booklet.
    The 901/03 ratios were A/F/M/S/Z, and was optional for the 68 911T. The standard 68T transmission was the 901/10 4-speed.
    The 902/0 ratios were A/H/Q/X.
    The 911L came with either a 902/0 4-speed, 902/1 5-speed or 905/00 Sportomatic transmission. The chart lists the 5-speed as standard except USA.
    The 902/01 was a 912 4-speed transmission, not used in 6-cylinder cars.
    Jon B.
    Vista, CA
