Thread: A/C compressor mounting question
    Aug 2011
    Eugene, OR
    The factory A/C parts for my '72T came on boxes. Now beginning to sort this out as another step in refreshing my car. I've got a question on the compressor mounts.
    Where does part #24 go? It looks like it might go from the inside of #28 (just below the long adjuster stud) down to one of the engine case studs using the special nut? Is that right?
    - Arne
    Yes, that is correct.
    Oct 2010
    Southern Ca.
    Actually it bolts to the top stud for the timing chain housing .
    Aug 2011
    Eugene, OR
    Got it all installed. Thanks, all.
    - Arne
