Results 1 to 10 of 14
Thread: 1965 911 Wiring Loom Repair/Replacement Question
    Junior Member
    Dec 2019
    RHODE ISLAND
    Hi All,
    I am working on a 1965 911 Project and am looking for any and all recommendations on the best way to refurbish or replace the wiring loom on the car.
    If anyone has experience with this, or has any contacts who might be able to help with the project that would be much appreciated.
    Bob
    Use the search function to locate an extensive demonstration of complete wiring harness replacement, posted not too many weeks ago. There are sources of new wiring harnesses for your car, such as Y n Z in California, or Kroon, overseas. You can also source individual wire stock in proper gauge and pattern configurations from such vendors if you plan to "patch."
    Aug 2009
    edmond, OK
    Talk to Steve at https://911highvoltage.com
    eric
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    +1 for Steve, he does a great job - he also posted a video how to on his you tube
    Nov 2008
    Finland
    +1 more for Steve, did a great full harness for me
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
    Mar 2018
    TN USA
    Eric, Matt, and Ville. Thank you for your support!
    Bob, if I can help with anything please let me know.
    Here's a video of taking one out.
    https://www.youtube.com/watch?v=14F0N4t1xZQ
    Junior Member
    Dec 2019
    RHODE ISLAND
    Thank you for all of the responses, videos and recommendations, very much appreciated!
    Steve: Thanks for posting the video, I will be sure to reach out at some point soon.
    Bob
    Senior Member Robert-Jean's Avatar
    Feb 2008
    Netherlands
    Hello,
    Unfortunately I have to replace the wiring harness in my car after suffering from a short in the VDO RPM gauge.
    The blue yellow wire that feeds the lights in the VDO gauges, fried a major part of the wire harness.
    Is it possible to remove the wiring harness with the engine and gearbox mounted in the chassis?
    Best regards,
    Robert
    Aug 2009
    edmond, OK
    Kroon is in your neighborhood. I would contact them.
    https://www.kroonwireharnesses.com
    Kroon Wire Harnesses B.V.
    A. Plesmanlaan 9
    9615 TJ Kolham (Groningen)
    The Netherlands
    eric
    May 2011
    Chelsea, Québec
    +1 for Kroon...
    Member #1616
