Thread: Identify Shock
    Member ProfHollan's Avatar
    Aug 2016
    La Jolla, CA and Albuquerque, NM
    Identify Shock
    Don't see a brand on this shock. Would appreciate help identifying. It is from a '73 911E Targa. Boge?
    Aug 2016
    On second look
    Quote Originally Posted by ProfHollan View Post
    I thought Boge because black but now see green on edge of unit. Bilstein? Unfortunately car is at paint shop and I do not have access.
    Oct 2008
    Burford, ON, Canada
    If this is a roll pin, then I would say it is Bilstein.
    Usually under the paint will be the manufacturers name.
    Nov 2010
    North Carolina
    Bilsteins are installed upside down like that with the shock body as the piston. It could also be hydro-pneumatic struts, but more likely Bilstein.
    Aug 2016
    Thanks for the help. Turns out it is a Boge.
