Thread: recaro Idealsitz foam source?
    I have a pair of Idealsitz S seats (basically the '74 on sport seats, but with separate headrest) that would benefit from new foam in the outer bolsters.
    Does anyone know of a reliable source for such foam?
    3 days, one answer (PM)... Where are the pros??
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Repairing is easy if it's not disintegrated.
    A bit of foam, the right glue and some small belt sander / or rotary grinder.
    Or overkill version:
    3D-Scanning.
    programming (6-Axis mill or Robot)
    Take a block of foam immerse in water freeze the soaked block then mill.
    I like your thinking. I'm only a 3D mill short.
    That said, foam and glue, it seems. I'm wondering if someone has parts/capacity to reproduce.
