Results 1 to 9 of 9
Thread: 901 transmission (1970T) shift rod removal
    Oct 2018
    Orange County, California
    Hello,
    I am looking to install a Fab Car shifter to my stock 901 transmission (1970T) and would like to know if it is possible to remove the stock shift rod from the tunnel WITHOUT removing the drive train? Any assistance you can provide would be greatly appreciated.
    Thank you.
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
    I don’t think so. Does the Fabcar shifter go inside the tunnel or on top of the tunnel. If on top, cut the old shifter out in little pieces.
    Sep 2012
    Colorado
    No, the shift rod can only be removed with the drivetrain out. I had never heard of Fab Car shifters and just did some Googling. It looks like they were around about 7 or 8 years ago. Everybody who mated them to a 901 gearbox seems to have hated that shifter. I bet you got a great deal on it!
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    Oct 2018
    Thank you for the advice - much appreciated.
    Oct 2018
    Thank you for your input. I too was unaware of the Fab Car shifter until recently. The shop owner who is selling it to me is one of the premier air-cooled race engine builders on the west coast, and he highly recommended it to me. He offered me an NOS one at a very reasonable price.
    Quote Originally Posted by raspritz View Post
    Oct 2010
    Southern Ca.
    I once tried , almost but can't be done .
    Sep 2012
    Colorado
    I wish there were a great shifter solution for the 901. There isn't, and the 901 just isn't the world's best transmission. What is your goal? For a street car, I'd stick with the stock shifter. For my racecar, over the past decade I've tried the stock shifter, a short shifter kit (I forget whose), the JWest, and the Wevo. I'd love to try the Hargett, but I'm not sure the Hargett 901 version was ever actually made. The Fab Car is a tower shifter, which brings geometry issues trying to mate to a 901. So far, the Wevo seems to be the best of a bad lot. At the moment, mine is out of the car as we are modifying it to limit travel and protect the innards of the transmission and the shift rod clamp.
    Rich Spritz
    1969 Porsche 911T
    Oct 2018
    My car is a street car. When I upgraded to the 3.2 short-stroke, I found the 901 stock shifting to be very loose. I wanted to tighten up the shifting and limit travel.
    I am going to give the WEVO a try.
    Thanks again. Much appreciated.
    Sep 2012
    Colorado
    The most frequent causes of “loose” shifting are worn bushings in the tunnel or a degraded shifter cup. That said, the 901 is inherently loosely-goosey, and not tolerant of fast (racing) shifts.
    Rich Spritz
    1969 Porsche 911T
