Thread: torque value for banjo fittings on MFI fuel console
    Hi all
    Hope everyone is well and staying safe.
    Is there a torque value for the banjo fittings on the fuel console?
    Do you use a Loctite product in this area?
    There is also the overflow valve here, requires a box wrench...or a deep socket
    Bob
    73 911S Targa
    I have never seen a torque value for these fittings. And I would never use loc-tite on those threads.
    Jun 2012
    London, Ontario, Canada
    In general, torque for banjo bolts in fuel and brake systems are in the 14-40 lb-ft range. And they can snap pretty easily. Start low. An no loctite. It’s the crush washer that does the work.
    Early 911S Registry # 2395
    thanks - this helps.
    73 911S Targa
