Results 1 to 1 of 1
Thread: FS: Brackets for Luggage Comparetment Bulkhead Cover #911 551 067 00/03/etc.
    Oct 2009
    Indiana
    I uncovered these while re-organizing my parts storage. According to the parts manual, these are primarily correct for mid-year ('74-'77) models, which had a hard-cardboard cover over the dash bulkhead in the front luggage area. These are the brackets which attach to the hard cardboard/fiber-board that protects the equipment under the dash (part # 911 551 067 00/03/etc.), bowever, there appear to be several applications for the brackets, depending upon year/model/equipment/etc.
    As you can see, they are in unrestored condition, and need blasting/paint.
    The research indicates that there are several applications which use these brackets, and each application has a different shape of cardboard/fiber-board, depending upon model and application. I've noticed that a lot of the mid-year bulkhead covers are broken/damaged due to cramming stuff in the trunk, or they are missing altogether. The price range for 911 551 067 00/03/04/etc. appear to run from $200-$300.
    So, if you have a template for the cardboard/fiber-board version that meets your needs, you can buy a pair of these brackets and cut the board yourself, rather than shelling out $200-$300 for a replacement (plus shipping).
    The brackets are offered at $20 per pair, plus shipping and fees. (medium USPS flat rate within US would be ~$16.) As the photos show, there are 2 pairs.
    Thanks for looking.
