Results 1 to 8 of 8
Thread: MFI fuel filter
    Jun 2011
    Bellingham, WA
    MFI fuel filter
    why is the MFI fuel filter so large (& costly) compared to a CIS fuel filter?
    Because the super fine machining and fit in the injection pump can’t have any contamination.
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    I have found that the replacement filter elements are not doing their job. I recommend adding an additional filter somewhere.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Quote Originally Posted by BURN-BROS View Post
    What issues are you finding? Is the filter element breaking down, etc?
    Sep 2003
    Camarillo, Ca.
    That foreign material is getting thru. So it's just an expensive nothing at this point.
    Aaron Burnham
    Burnham Performance
    805-240-6931
    Aug 2011
    Eugene, OR
    I added a filter between the tank and the fuel pump. Protects both fuel and MFI pump.
    - Arne
    Sep 2003
    Camarillo, Ca.
    That's Typically what I do. I also add a small see thru filter in the engine bay between the filter console and the return line. It gives me an idea if I have a problem and is relatively safe as there is no pressure there.
    Aaron Burnham
    Burnham Performance
    805-240-6931
    Nov 2003
    Santa Monica CA
    Is Bosch still making these filters. I heard they were NLA, so I bought three in 1998 while they were still Bosch. What are they now?
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
