Results 1 to 10 of 16
Thread: Targa Top Removal Tool
    Aug 2006
    Chicago area
    Sale on hold for the moment pending further research. Just want to make sure I identify it correctly.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Junior Member
    Jul 2019
    Chicagoland
    Hi I’m interested. I’ve got a 73 targa in need of the driver side handle (not sure if there is a difference). I’m local to you in Hinsdale. Lmk. Thx, Lee
    Don't want to kill your deal. That's for the earliest version ('67-'68). Later version handle is rounded over with no ribs. Value of this one is that's way under priced. They get $198.00 on the Samba. For later version try Paul Chapell. Early guys should jump on this. If you don't get any takers for this in the next 5 days, I'll take it at this price and make some money on resale at Hershey.
    Quote Originally Posted by doigthom View Post
    Almost positive that this part is through 1973, not specific to 67-68 as I have several original LWB targas and all of them have these tools.
    Jul 2011
    Chicago Area
    I have a '71 Targa and it has the exact same release handle as pictured above.
    Mike Fitton # 2071
    2018 911S Carrera White
    Aug 2006
    Chicago area
    Thanks Mike. I put the sale on hold so I can correctly identify this for the prospective purchaser. If it should go to an early early car (SWB), that is where I would like to see it go. Initial responder will still have the initial opportunity.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    See Rick Cabell's ultimate conclusion on page 2 of this thread. https://www.early911sregistry.org/fo...rga+Top+handle
    Rick, who I consider a friend, is incorrect this time.
    Quote Originally Posted by Soterik View Post
    It's correct for sometime into 72 as I recall. The part number stays the same definitely into 71 (and I had a 50K mile 2 owner 71 with the early ribbed version). I had a 73 with the next pebbled version. Part number in the 73 parts book does show a change from the earlier one. The earlier one shows 3 components to the early handle (so 3 separate part numbers).
    That's as much as I can add to the conversation....
    That sounds right by me as I don't have a 73 targa. But I do have a one-owner '69, a one owner '70, and a one-owner 72 and all three have the ribbed version.
    Feb 2012
    Florida
    I have a '73 (03/73), which I believe to be original, with the ribbed handles. Maybe Porsche was using up old stock on mine.
