Thread: help ID unique carb stacks
    Mar 2004
    Castro Valley, Ca.
    ID 47mm no taper. overall length 90mm top to bottom. not sure what the second flange is for.
    what effect would the extra length have ? (55mm stack for comparison)
    TIA
    1940 Mercury town sedan
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    It is provision for either air filter bases or for bodywork to separate the engine compartment from the induction/intake area.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Jul 2008
    South Florida
    Yeah, the flanges are probably for air cleaners... regarding stack length, short makes power at high RPM, long is better for low to mid-range. Helps to tune the exhaust length accordingly.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
