Results 1 to 8 of 8
Thread: Advice re: replica high butterfly ?
    Junior Member
    Feb 2016
    I'm building an RS 3.0 replica and would like to use high butterfly inlet . I have been warned against buying a replica setup. There seem to be a few available . Rothsport sell them and Mittelmotor . Wondering if anyone has experience with any of these setups ? I was leaning towards the Mittlemotor , thinking the Germans would build a quality product . I would appreciate any opinions on the problems with replica's ? I know I missed a NOS set that Patrick bought , ironically we both live in Australia.
    Quote Originally Posted by Spannerhead View Post
    . . . missed a NOS set that Patrick bought . . .
    Another one . . .
    https://www.early911sregistry.org/fo...ight=butterfly
    Replika . . .
    hth
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    You can easily spend the identical amount of money to adjust and correct the aftermarket throttle bodies.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    I have had 2 sets of factory HBF, they take a lot of work to correlate the throttles. The disadvantage to factory is 43mm ports required to match the throttles size. The aftermarket ones have smaller sizes available in the plates and port size. There is no plug and play with any HBF.
    I have a Mittlemotor set of HBs on my 2.7 twin plug. They are a well made product and supplied with linkages assembled for each 'bank'.
    Very little adjustment was necessary to get the butterflies opening together.
    Rothsport sell the EB Racing ones from the UK I think, Gordon may be able to confirm/deny
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Yes Rothsport sells the EB ones. Of coarse the 3.0 RS used regular “S” throttles.
    That project just gotcheaprr��
    Clyde Boyer
