Thread: Sway bar bushing installation
    Does anybody know the trick to installing the nylon bushings in the end links on the rear sway bar. I tried pressing them in with a vice, but it looked like they were just going to deform. Next I placed a small socket in the open end and tried the vice again, but felt like it was just going to push the socket through the closed end. I tried putting them in the freezer for an hour or two, but saw no improvement. Perhaps they need much more time in the freezer. So is there a trick to this or do I just need to get a little rougher with them?
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Jul 2006
    Corvallis, OR
    Don't freeze microwave a cup of water and drop them in. Then lube with dish soap (a lot) and get rough with them. Will go easy at that point.
    72S, 72T now ST
    Thanks for the tip Longballa. I had thought about using my heat gun, but sometimes I tend to set things on fire with it! I boiled them for several minutes and tried again with the soap (was using silicone grease) but still, they just wanted to deform. Finally I resorted to putting a slightly larger bevel on the leading edge of the bushing. It still took a lot of pressure and deformation of the bushing, but once the leading edge started they slid right in.
    1969 911S
    I just put in a vice and start squeezing, then use a pair of channel locks to slightly squeeze the bushing as I close the vice, once you get that first lip in the end they pop right in.
