Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: MFI electric fuel pump no pressure
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    The electric pump does not set system pressure. The check valve at the filter console does. You can do a quick test by pinching the return hose in the engine bay while monitoring fuel pressure.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Granted, but if you disconnect the feed line to the filter console, and dead head the pump it should be 2 bar of pressure,,,,right???
    Sep 2003
    Camarillo, Ca.
    I don't remember what electric pump pressure check valve is anymore. 1bar? CIS is 2?...That may be system pressure. If you dead head the system at the Return line of the filter console and see pressure, AND the volume is in spec, I would look at the MFI check valve. If you see no pressure then I would chase the electric pump first, and then verify check filter console checkvalve.
    Aaron Burnham
    Burnham Performance
    805-240-6931
