Results 1 to 7 of 7
Thread: Zenith carb adjustment screw source
    Jul 2014
    SF Bay Area
    my 1970T Zenith carb is missing the screw in the pic below, anyone know where I could buy one?
    Not finding at all the usual sites.. Thanks very much.
    Here is where it goes
    here is a pic of the one from the other side
    I don't remember if that is a 4 or 5 mm screw, take the other one, go to Ace hdw. get that size screw, cut the head off and cut a slot.
    Jul 2014
    SF Bay Area
    Measured and looks like a 5mm, thanks Ed. Thread looks very fine, wonder if my local Ace will have that.
    It's probably a 5 X .8 mm thread pitch, Ace will have it.
    Feb 2003
    Los Angeles
    You could also try Paul Abbott.
    http://www.performanceoriented.com/
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Dec 2009
    Copenhagen, Denmark
    Didn’t Paul retire? His website looks up to date though.
    Try Belmetric.com
    Or
    Alfa1750 on EBay: https://www.ebay.com/itm/290370350583
    He has all the zenith carb parts and ships very quickly from Italy.
    James Hurst #1638
    R Gruppe #514
    Jul 2014
    SF Bay Area
    Appreciate the replies - friend of a friend had one, resources above bookmarked!
