Results 1 to 8 of 8
Thread: sportomatic gauge different than regular?
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Dear all
    concerning the gauges of the 68 swb sportmatic I do wonder what and where is the difference:
    the oil temp / pressure gauge is having the
    part number 905 641 501 10
    pressure unit scale is form 0 -10
    oil temp just the coloured scaling
    the regular gauge is having the
    part number 901 741 501 05
    What had been the technical reason for the two different gauges?
    Can I interchange these?
    Can I use the Sporto Unit in a 68L?
    or
    does the 68L need the correct gauge,
    br
    stay safe & healthy
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    The Sporto oil temp gauges have a warning light at the top of the scale and standard trans car gauges do not.
    Because the sporto shared the oil with the engine I assuming this was a extra warning so you wouldn't cook the trans if the oil got too hot.
    They're totally interchangeable except the warning light will not work.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by aturboman View Post
    +1..............................
    Feb 2012
    Netherlands, Leiden
    I bought a 68 SWB 911 with the 905/01 Sportomatic gearbox, according to the Kardex.
    Does anyone know if it is possible to connect a 905/01 to a normal 901/03 T engine? I think the correct engine is a 901/13, but I have only a running 901/03 engine. I am not sure if the Sportomatic engine cases had some alterations?
    Some pictures of the Sporto:
    Oct 2008
    Burford, ON, Canada
    The engines are essentially identical, but the intake stacks had an extra vacuum port, and the Sporto oil pump was driven by a cam, so there are engine tin differences also. Plus the vacuum tank and plumbing & the Sporto oil tank and plumbing. That is a start anyway. Then there is the pedal cluster and the gearshift. Does the car also have the S brakes?
    Feb 2012
    Netherlands, Leiden
    Thanks Dave!
    Still not sure if I should start with a normal gearbox and try to acquire all sporto parts over de coming years, or do sporto from the start.
    And the sporto also had a different flywheel? And extra parts:
    Does anyone have a schematic overview of the sporto setup in 1968 cars?
    Oct 2008
    Burford, ON, Canada
    Jesse, it would depend on what parts your car currently has. If it has been fully converted to a manual gearbox, then I would advise finishing it up as a manual. It may take some time to pick up all of the Sporto specific parts. Get a PDF of the parts manual that covers 1968, and start a checklist of what parts are needed, and check off what you currently have. I have a Sporto gearbox that I only need some gears from. I also have a copy of the parts manual, but it can be downloaded directly from Porsche.
    Dec 2008
    Black Mountain, NC
    Haul, You have a PM
    Best Regards
