Thread: Bumper Horn Pad
    Jul 2011
    Chicago Area
    Bumper Horn Pad
    Can these be saved once you lose one of the attaching threaded studs, top one broke off during removal. Other than the broken stud pad is in excellent original condition. I know the repro ones are sh*t.
    Name:  IMG_6299 (1280x960).jpg
Size:  160.5 KBName:  IMG_6300 (1280x960).jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Aug 2011
    Eugene, OR
    If it were mine, I think I'd give it a shot, Mike. I'd probably try drilling a smaller hole in the broken stud and either thread the new hole or use a very small self-tapping screw. That and a touch of weather-strip adhesive would probably do the trick.
    Looks like it is for the front, not the rear?
    - Arne
    I saved a similar situation, but with a longer remaining stud, by using a makeshift shield around the stud and end-welding a threaded rod to the stub. Worth a shot.
    Jul 2011
    Chicago Area
    Quote Originally Posted by Arne View Post
    Actually for the rear Arne, 3 studs versus 2 studs on the front ones.
    Mike Fitton # 2071
