Results 1 to 10 of 12
Thread: SWB steering issue
    Aug 2010
    Colorado
    SWB steering issue
    I'll start by saying I had the front suspension off to move the gas tank to run hard fuel lines through the tunnel. I've had the front suspension off 3 or 4 times without this issue.
    When I button up the front suspension and steering box the splined shaft that connects to the steering box is off so far I can barley get the bearing on as the shaft is actually pressed up against metal by the upper mounting bracket hole. If I tighten the bearing in place it puts a strong side load on it and it clicks at about dead center and also causes the shaft to pinch to one side when the steering wheel is off. I've never run into this before. When I loosen the two bolts that hold the rack to the crossbar it goes into place. I tried loosening all front suspension contacts in case there was a bind somewhere and carefully retorqued the bolts. It didn't help. When the steering wheel is not connected to the steering box both the steering wheel and the steering box move all the way in both directions smooth as silk.
    What gives? Do I need to rebuild the box, tie rod ends twisted, or?
    The shaft should be pointing up not down.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Aug 2010
    Colorado
    I released the tie rod ends to see if they were off. It didn’t help. When the steering rack is just a little loose and pressure is on the rod to move it in the proper position you can see the whole rack wants to rotate. There are no pucks or washers between the rack and cross bar.
    I put a long bolt in the rack and wiggled it to see if there was play and couldn't feel any.
    www.reSeeWorks.com
    Aug 2010
    Colorado
    I went home and blew this picture up and noticed a 180 degree scratch. What do you think? About the only thing left that I can think of is pull the rack and look inside. I would appreciate some feedback here.
    www.reSeeWorks.com
    To me I'd say the steering rack goes where it has to when you bolt it on the crossmember. Any chance that is wrong?
    May 2014
    South East USA
    a bit of a puzzle.
    There is a "replaceable" bearing at the bottom of the rack.
    It's just under the cap.
    It seems like that bearing is missing. Allowing the shaft to go out of proper angle.
    That's almost the only thing I can think of. That would make your photo like that.
    Are you sure when bolting in the rack. You didn't squish a fuel line or the fuel pump wire?
    Is the steering rack shaft bent from a crash?
    Aug 2010
    Colorado
    I'm going to borrow a crossbar to see if mine is bent. Then a rack after that if necessary. I pray it isn't the tub.
    www.reSeeWorks.com
    Aug 2010
    Colorado
    The crossbar is being replaced.
    www.reSeeWorks.com
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    What part are you calling the cross bar? Forget that
    I've re read it now, you have found that your crossmember is bent?
    Aug 2010
    Colorado
    Yes slightly bent.
    www.reSeeWorks.com
    Aug 2016
    NE Ohio
    subscribed
