Results 1 to 8 of 8
Thread: suggestions on a larger oil tank for '68 SWB with a larger potent engine installed?
    Feb 2004
    Texas Gulf Coast
    Hi all,
    As I get further down the road on my '68 Rat build I'm thinking about oil capacity a bit. At present I have an original tank that has been slightly modified to work with a auxiliary front oil cooler (modified factory setup).
    With a 2.8 twin plug engine installed I'm concerned that I may need a bit more oil capacity.
    Any suggestions on swapping another tank or maybe having mine modified? I think I've read that some have used a tank out of a 964. Anyone have any thoughts or experience on that as an option? ...or any other suggestions?
    Thanks in advance (again)
    Jay
    -Jay
    Seabrook, TX
    '68 911T project -The Rat
    '74 911 3.0 EFI Twin Plug toy
    '80 Weissach 3.2 S.S. Grocery Getter
    '70 914/6 GT vintage race car
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    Hi Jay, long time! What's intended purpose of the 68?
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Feb 2004
    Texas Gulf Coast
    [QUOTE=BURN-BROS;1063046]Hi Jay, long time! What's intended purpose of the 68?[/QUthOTE]
    Hi Aaron! This is just a fun build. I'll use it for the hill country rallye and just messing around. I will likely take it to the track just to see what it is like but this will likely not be a dedicated track car or race car. ...unless it ends up just being too much fun on the track but as long as I have the 914/6 likely it will simply be a street hot rod, hill country rallye type car and truly a rat but with some really cool bits installed.
    -Jay
    Seabrook, TX
    Feb 2007
    Cheshire, UK
    Jay
    Some of the Sports Purpose cars used a Sporto tank which I believe is larger.
    Tim
    Early 911S Registry #1167
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Bantam View Post
    Jay
    Not true. A sporto tank just has extra fittings for the cam driven sporto pump. Later turbos use a sporto tank to supply oil to their turbo.
    Jim
    PS: It would be much more efficient to just add an oil cooler with Elephant Racing lines. You increase the oil capacity and get significant reductions in operating temps.
    Jun 2012
    London, Ontario, Canada
    Jim's suggestion is probably the more relevant one. You want cooling capacity, not necessarily more oil (although that doesn't hurt).There's a lot of oil volume in the lines from the engine to a fender mounted oil cooler, and a lot of volume in even something like a trombone oil cooler. The finned Elephant lines produce a lot of cooling on their own because they have good access to air flow.
    Ravi
    Early 911S Registry # 2395
    Feb 2004
    Texas Gulf Coast
    Thanks all. ...car has carrera cooler and oil lines modified to work on SWB.
    -Jay
    Seabrook, TX
