Results 1 to 10 of 12
Thread: FS: NOS Porsche 911 2.3 ST brass oil line set +tubes
    Apr 2011
    Germany
    Up for sale is a NOS Porsche 911 2.3ST brass oilline set. The drivers side oilcooler protection plate is retro.
    I have one set including oil tubes and one only brass set.
    Full set is 4200 Euro including shipping worldwide. Brass set tubes only is 3000 Euro...also have the original clamp for luggage compartment.IMAG4559.jpg at
    Porsche 911 S 1971 Kremer race car
    Aug 2010
    Colorado
    That is very cool!
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    Quote Originally Posted by Chris Pomares View Post
    That is very cool!
    I see what you did there Chris
    Apr 2011
    Germany
    Dome updates how system looks mounted....IMAG4617.jpgIMAG4618.jpgIMAG4619.jpg
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Quick questions.
    How much extra oil do these systems take to fill ?
    How do you drain the lines and system at oil change time?
    Mark
    Jun 2012
    London, Ontario, Canada
    I recently swapped out my '74- trombone for a proper '73 trombone. The trombone I took out had a regular can of beans worth of oil (~400 ml) in it. The trombone stretched out is probably about the length of the rocker lines. So the supply and returns probably each have a similar amount, so for a trombone system you are looking at something like 1.2 litres. Not sure what the volume of the radiator systems are. Probably not that different.
    Ravi
    Early 911S Registry # 2395
    Schöner, seltner Tank!
    Same with the 917 Style Strut brace, I wished my car had it also....
    Feb 2017
    Auckland NZ
    Thanks Ravi,
    I am assuming that the oil in the system just gets diluted into the fresh oil on service.
    Mark
    Jun 2012
    Yep, unless you blow it out by undoing the lines at the thermostat bypass valve. Should amount to about 10% of the oil in the system, give or take.
    Back in the day, around, 1980 I had a 2.7 1974 normal, daily driver, with non-factory air and no cooler. On hot LA days, oil temp would get around 250 with the A/C on.. I bought a take off system from a Carrera of the same year: a simple Loop cooler, no fan; half the cooling, more or less, comes from the line up to the loop. With that set up, my oil temp never got over 210 and I felt much better. Thanks.
    -Allen-
