Results 1 to 10 of 10
Thread: Lightweight aluminum scissors jack
    *SOLD* Do you really want to use the factory jack on your early car? This compact and lightweight 996 jack does the job without the worries. $65 plus shipping and pp fees
    I'll buy it.
    Zip code 94402
    San Mateo, CA
    Apr 2004
    35,000 ft
    Curious, where do you recommend placing this when using it....I’d worry about the nub that locks into the jacking points of the later cars would dent our cars.....I was under the impression the aluminum 944/951 jacks with the slit in the top surface was the way to go, the slit slides over the body seam near the jacking point or by the rear torsion bar.
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    This one looks very similar to the 944 Jack which I have. I put a block on top and use it in the usual spots underneath.
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    Mar 2016
    U.K.
    Quote Originally Posted by Peanut View Post
    Scott
    I recently bought a 944 jack for my 73. Apparently a ice hockey puck with a carved out hole works well too.
    Apr 2004
    35,000 ft
    Jun 2012
    London, Ontario, Canada
    Quote Originally Posted by 911GP View Post
    Exactly what I use. Stock jack lives in the basement.
    Early 911S Registry # 2395
    Payment sent
    I have one of these to sell as well
    Quote Originally Posted by blucille View Post
    Aug 2012
    Florida
    Here's what I did to use the "944 jack" with the bump in it. A few pieces of Ipe wood, although a hockey puck might work better as it is a bit softer and not as large.
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
