Thread: 68 steering column mount help
    68 911/912. This is the steering column mount. So am i seeing this correctly. These should all have hex heads on them? So all three have been twisted off? Not sure how else I would get these out.
Size:  79.1 KBName:  F1122F11-0514-4DEE-BA09-E03D7D2DD1B2.jpeg
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    68 911/912. This is the steering column mount. So am i seeing this correctly. These should all have hex heads on them? NOPE So all three have been twisted off?YES Not sure how else I would get these out.thats the idea behind those type of tear-off screws to not get em out...but hammer and chisel is your friend
    https://www.google.com/search?q=abre...w=1536&bih=722
    Yep. Chisel worked perfectly. I was almost going to take a grinder to them. I’m going to just replace these with some Allen bolts.
    Thanks.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by stubble88 View Post
    Thanks.
    That is the common sense way to replace them.
    Jim
