Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Are 14" Fuchs part of MY70 911T Comfort Package?
  1. #11
    Aug 2011
    Eugene, OR
    Quote Originally Posted by 71gold View Post
    ...Mine was a 71T sunroof coupe (12/70 production)
    They read the listed option codes and associated descriptions....
    #G103-Koni Shocks...
    This doc for late '71 MY (dated Mar. 9, 1971) shows Koni shocks for T & E coupes as 402.
    - Arne
  2. #12
    Did a search and found that ThomasTe presented a list of codes (2008)
    Re : Koni Shocks he shows
    M103 Koni Shocks
    M402 Koni Shocks front with “S” brakes & Koni Shocks rear.
    Believe my hand letters (transcribed) may be incorrect,
    Since all my notes of codes did not have an M before the number.
    After studying my notes I actually had an arrow looped ( looked like a G )...to the number from Koni Shocks .
    Thanks for correction, now makes sense.
    Should be M103
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
  3. #13
    Oct 2008
    Burford, ON, Canada
    M103 = Koni for 70 & 71
    M402 = Koni from 1972
  4. #14
    Oct 2008
    Burford, ON, Canada
    A01 was also listed on my COA which I did get before they stopped the engine and trans #s.
    Not sure the extent of leather.
    G was in my notes ...I have seen M used I other posts , yes Koni 3” struts and believe they were aluminum S calipers (will check on shelf)
    M490 ...yes did have left antenna , loud speaker and noise suppression on car but not in their description provided .
    CO2.....reviewed my notes , corrected to rest of USA.
    Good to see you have this service have friend with 70 needing info but he has what he believes are the original engine and trans , can you verify this if numbers provided ?
    frank
    Koni 3” struts can only have cast iron calipers, aluminum S calipers require the 3.5" struts. Knowing the calipers with the struts is very important with this option.
    I can get the engine #, even if not known. Transmission # may not be available, but can usually tell if it is likely original. The more VIN & engine & transmission # sets I get the better my understanding. I like to get the production # to verify, and it also helps to build the database. If the compliance decal on the left door latch post exists, then the date code is very helpful.
  5. #15
    Davep
    Thanks again for accuracy......
    So checked the shelf of parts and the Koni struts are 3.5” spacing with S calipers.
    Sorry for confusion but been siting for awhile.
    Been welding and body for last year and 1/2 !!
    Will send you a PM with some info on the 70 .
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
