Thread: Looking for MFI Part # for Return Oil Seal
    So I have a freshly rebuilt MFI on my '70 911E and as I'm test driving it I found a pretty big oil leak. It appears to be coming from the cover plate on passenger side of the pump where the return oil line(??) is attached. I checked the parts catalog but don't see anything shown for the gasket. Any ideas on where to find one?
    Chris
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    I think it's listed here:
    http://www.911mfi.com/14.html
    1969 S Coupe #761
    Early S Registry #1624
    Thanks beh911! Ever used fiber or cork rather than neoprene rubber?
    Chris
    Oct 2010
    Southern Ca.
    Why didn't the rebuilder use a gasket that doesn't leak ?
    I pulled the cover off the other day and the gasket was fine. Not sure why it was leaking. I did find some type of silicone on the gasket so I cleaned everything up, reinstalled it and no leak. I haven't gotten it up to operating temperature so I don't know if things will change.
    If those gaskets get over tightened, they can leak. I always use a thin coat of curil t on both sides.
