I think 8-9 is too steep given they need a full resto someone will be in to them for $12k at that rate but yes 73 only seats so should not have been in a 72
unless replacing other seats.Recliner lever has also either broken or bent it's "hold in place pieces" as you can tell by their incorrect angle and it is a common problem but usually easily fixed with a small hammer
