Results 1 to 8 of 8
Thread: Swap door handle sides?
    I have 2x 1969 door handles both for the same side, is it possible to flip the barrel in them 180 degrees in order to have a pair?
    Neil
    May 2006
    CT
    The release lever arms are different L vs R
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2009
    SF Bay Area
    The handles are the same. The only difference is the lever. You need one marked “r” and one marked “L”.
    Jim
    Jim
    I've looked at three sets and can't see any "L" or "R". Where should I be looking?
    Aug 2017
    el sobrante ca.
    The end arm that is held on with a screw. that's the piece that you would have to have a right or left piece ... just the arms are right or left . just like the ones on your body if you removed them and tried to put your right arm on the left side of your body .... no Bueno amigo...
    I looked at my 1968 handles and thy do not have L or R. Another one of those 1968 quirks
    May 2006
    CT
    1970 and later handles are marked left and right but the 69‘s are not marked.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Aug 2009
    SF Bay Area
    Quote Originally Posted by LiveFromNY View Post
    Sorry, my bad.
    All the handles since 1970 have marked levers. Not having a 68 or 69 handle handy I assumed that they were marked as well. That's what I get for assuming. I usually don't to that.
    Jim
    Sorry, my bad.
    Jim
    Let's see, Jim...
    That makes 99,999 times you were correct and 1 time you were incorrect (roughly).
    You'll never catch up to my wrong answer record at that rate!
