Results 1 to 8 of 8
Thread: 1969 911S MFI - mag stacks, throttle bodies, linkage
    Jun 2015
    Oceanside, Ca
    1969 911S MFI - mag stacks, throttle bodies, linkage, fuel lines
    Selling a nice lightly used since rebuilt set of 1969 911S intake manifolds, throttle bodies, all linkage, fuel lines, microswitch, and bottom half of the metal airbox.
    Part numbers
    Stacks: 901.110.309.0R
    Throttle Bodies: 901.110.101.0R
    Price: $2800
    Jun 2015
    Oceanside, Ca
    Linkage, fuel lines, and airbox clips
    Jun 2015
    Oceanside, Ca
    Bump for this nice set.
    Jun 2015
    Oceanside, Ca
    To the top, price reduced!
    Jun 2015
    Oceanside, Ca
    Little more info; the stacks are 46mm at top (air horns match exactly) and 39mm at the bottom. The throttle bodies are 39mm with small step at edge to 38mm opening/butterfly and taper to a 36mm port at bottom where it meets the head.
    Jun 2015
    Oceanside, Ca
    Still have this rare ready to use set
    Jun 2015
    Oceanside, Ca
    Bump to top
    The nice thing about 69 stacks is u can use carb metal air horns, @46mm. 70-71 are 43mm, very difficult to replace air horns. Injection pipes are not 69 though.
