Results 1 to 9 of 9
Thread: Difference between 915’s
    Member#2944
    Sep 2007
    San Jose, Ca
    Had some major work done on my’74 911 and was surprised when
    the shop informed me that the transmission was from a ‘72.
    Are there any differences between the two years?
    Tony
    '68 912 SWT White
    '74 911 Targa Lime Green
    '03 Boxster S
    ‘13 Cayenne GTS
    Quote Originally Posted by 911+1 View Post
    Tony, in most respects they were the same.
    The gear ratios were different, and the 72 input shaft oil seal could only be replaced from the inside.
    Jon B.
    Vista, CA
    Member#2944
    Sep 2007
    San Jose, Ca
    Thank you Jon. The input shaft oil seal is what tipped the shop off to the year. Guess it’s a one year thing.
    Tony
    Tony
    '68 912 SWT White
    '03 Boxster S
    ‘13 Cayenne GTS
    Tony, from mid-73 through 75 the oil seals could be replaced from the outside with special tools.
    From 76-on the guide tubes containing the oil seals were removable.
    Many times the 73.5-74-75 transmissions are mistakenly identified as having oil seals that cannot be replaced from the outside, due to their non-removable tubes.
    Jon B.
    Vista, CA
    Member#2944
    Sep 2007
    San Jose, Ca
    I’d imagine the serial number would help?
    Tony
    '68 912 SWT White
    '03 Boxster S
    ‘13 Cayenne GTS
    Yes, or the transmission type, if they're still visible and not heavily scraped. A photo would be good, if you cannot read them clearly.
    The numbers were stamped into the lowest point of the transmission, just to the rear of the drain plug.
    Jon B.
    Vista, CA
    Aug 2011
    Eugene, OR
    Quote Originally Posted by Jon B View Post
    Typically scraped or ground down to oblivion, by now. Great thinking to stamp those numbers in the very lowest clearance part of the car. Mine is totally destroyed, as were the numbers on my friend's '73.5.
    - Arne
    Member#2944
    Sep 2007
    San Jose, Ca
    got the car in the air and it is a '74 according to the serial numbers. 7340982
    thanks for the assist.
    tony
    Tony
    '68 912 SWT White
    '03 Boxster S
    ‘13 Cayenne GTS
    ...the shop informed me that the transmission was from a '72.
    got the car in the air and it is a '74 according to the serial numbers. 7340982...
    Yes, I thought they might be wrong.
    The shop saw the non-removable guide tube and mistakenly assumed it was a 72 transmission.
    The guide tubes were only removable from 76-on.
    The seal in your 74 transmission can be replaced from the outside, using special tools.
    Jon B.
    Vista, CA
