I have reorganized my collection of early Porsche parts and have several new offerings.
Contact me if you see something you want or even if you are interested in a related item. I probably have it. I am selling the following now:*
1. (5)3-pin CDI units 12 MO warantee-$425, with rebuildable exchange-$275.*
2. (5) Weltmeister-or equivalent gated short shifters-Porsche body(05 or 06) and custom Seine gate-$350. Add $55 for knob and $19 for new boot. Shifter alone $275.
3. (2)Carrera cooler kit ($695) coolers-(good shock mounts,*
short oil lines, and mounting hrdwr). Flexible AN16 Aeroquip oil cooler lines,thermostat and fittings($550)-complete front to back setup. Oil plate cooler kits-$250.*
4. Mocal Oil Thermostat AOT2 -$175. AN12 fittings for Mocal-$20, SC/Carrera Oil*
Thermostat-911.107.163.OR (good threads)-$250.*
5. 1970-2 911 rubber oil Lines and fittings(inquire)
6. (1)180 MPH (mechanical) Carrera rebuilt speedo-$650.*
(1)2.2L 911E (70/71) $8500-$10500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(1)2.2L 911S (70/71) $10500-$12500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(1)2.0L 911E (69) $8500-$10500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(2) 2.4L 911E (72/73) (inquire) Plastic Stacks/Throttle bodies no MFI pump*
(10)2.4L 911T (72/73) $6500-$8500 Plastic stacks and MFI pump and fuel pump
8. PARTIAL MFI SYSTEMS OR PARTS eg.-injectors(6 untested $375 or
Tested $500), fuel consoles $550, MFI fuel pumps rebuilt $350-450, air boxes-$550, etc. e.g. 1972/3 2.4L 911E stacks and throttle bodies-$3000. For S-$3500.
9. (3)1972 911S oil console-$550, (5)1972 911T oil console-$425.
10. Volvo Turbo fuel pump/regulated for MFI applications(3 port direct substitute for*
Bosch 001)-pressure and flow tested-$350
(3)1972 911 $350-550(mint), (5)1966-1971 911 $350-$550(mint).*
12. (1)1969-1973 headlights with bezel $150, two-stage rear window switch $150.
13. 911 (1969-1973) mufflers-(1), Bursch(2/1), flowmaster (1/1)x2-($150).*
14. Early fog light switches-new rubber knob and symbol $225-working light. Cigarette lighter with rubber knob and excellent symbol $200.
15. New clutch plate for 1972 915 (225mm) $175.
16.. Early 911 jacks –good to excellent condition – used $150-175.*
17. 2.4L 911S stacks (pair excellent condition)-$2250, 2.4L 911S Throttle bodies-(excellent condition-$2500). 2.2L 911S 009 MFI pumps-$5500.
18. TTG 1969-73 fog lights-restored Hella TN2,4&6($425,$225&$375), Used $375-250. Fog light covers-$125 Give your car that special look. Inexpensive aftermarket fog lights $150-350. Free reproduction mounting brackets with purchases over $375
19. Good starter motors 69-73 $125—200.*
20. Rebuilt (new o-rings/sealed) MFI electric fuel pumps-flow tested to spec.-$450, Carb.-$350, and CIS-$350. 914 2L Jetronic Bosch fuel pump $250. Bosch fuel pump rebuild $$250+parts+materials. Includes flow and leak test data.*
21. Gold Porsche lettering for 1972 911S targa (TBD).
22. Rear bumper S molding(pair) $250
*Included are the following: pump support bracket and AL spacer, oil breather plate with
cold start thermostat, oil line to pump, fuel console with bracket and filter, 6 fuel lines, 6 fuel injectors, free moving MFI pump with good pulley, throttle stacks, bodies, crossbar, and linkages, air filter housing, air filter, and snorkel, flapper box for 72/73 air intake.*
Inquire about additional parts. 20 years of early 911 collected parts mainly 1970-3. Pictures available upon request. ( X) indicates units available. email:*pgeorge911@aol.com, Telephone 952 835-9969
Old 06-23-2020, 12:12 PM
