Results 1 to 10 of 18
Thread: Help - identify piston
    Jul 2015
    Ohio
    I need some help identifying the set of pistons before I sell.
    Stamping inside:
    Top of Piston:
    I think they are 67-68 S. Rings are there some rust, No wrist pins. Have been sitting on shelf for quite a while.
    Input? Value?
    Steve
    Piston Heads,
    Those are 2.0 ltr. 69S high compression 10.3:1 Pistons. Thanks.
    -Allen-
    Restoration newbie.
    Jun 2007
    San Francisco
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    69S is nominally 9.9-1 C.R. These pistons have a 69S nr. but have the more round valve cutouts like 67S. What are the cutout diameters?
    Quote Originally Posted by 66S View Post
    All I know is what the spec sheet here says (it is the same one in the link-I find always just best to post the item(s) rather than a link. Thanks.
    -Allen-
    69S pistons
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Quote Originally Posted by Theunz View Post
    69S pistons
    You say "1969 Datsun 2000...worth less, but more valuable"
    Amazing oxymoron !
    Quote Originally Posted by Allen Henderson View Post
    Amazing oxymoron !
    Value is not necessarily measured in monetary terms.
    1969 911S
    Ok. However, to my mind, $$$$$ is probably the best metric. In the new world we are living in, that may change...or some would wish it so Thanks.
    -Allen-
    May 2006
    CT
    The part numbers shown on the chart or actually the casting or, in this case, the forging number. Those are cast or forged into the part when the rough pistons are made. The final part number is determined by the machining process. I believe that both the 67/68S pistons and the 69S pistons could be made from the same forging.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
