Thread: Rear Signal Housing "Gasket"/Glue ('69 - '73+) Questions
    Anyone know what this gasket or other material is and where to source it or something similar?
    Happened to be cleaning up my rear housing a little the other day, and noticed some small remnant of an almost putty like substance, but it's all mostly gone. Then saw this photo listed as a NOS part and noticed there is indeed something there.
    Recommendations for the glue used to attach the lens gasket would be helpful too.
    Thanks in advance for the advice.
    Name:  Rear singnal housing gasket.jpg
    Dave Reu
    Member #3949
    1973 Silver Metallic 911S
    Wurth Weatherstrip Adhesive works very well for lens gaskets:
    https://www.pelicanparts.com/More_In...=0&SVSVSI=911M
    No idea what the factory uses to secure the back housing cover. One of my guys fixed one of mine with JB Weld before I got to him. Sure hope I never need to open it back up again!
    It was a 'putty like' gasket, when I need to reseal I just use normal gray dum-dum.
