Results 1 to 9 of 9
Thread: Need source for Solex carb label tags
    I thought Stoddard's was making repo tags for carburetors but that appears to be incorrect. I would be grateful if someone could provide a source for the aluminum tags attached to the Solex 40PI carbs like the one below:
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Seems like these would be very easy to fabricate, especially with your skills Paul. But the stamping might be another matter to get dies that are exact matches.
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    Partsklassik has them for the PII. Perhaps they have the PI tags too.
    https://www.partsklassik.com/p-1077-...SABEgIUPvD_BwE
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
    I could get custom stamps made but much easier to "Click & Buy" if available.
    Thanks for the lead! I saw the tags for the 912 fuel pump but not for Solex 40PI carbs. I'll email & ask if they have other tags.
    Paul Abbott
    Early S Member #18
    530.520.5816
    Oct 2008
    Burford, ON, Canada
    They certainly list a lot of tags, just do not list the ones you are looking for. I assume they should be able to make them. I wonder if they also can supply blank tags. What is the hole size? I assume it is smaller than 8mm.
    A set of custom metal stamps would be required that match the font, I decline to chase that rabbit. However, I'll contact them to see if they would make a batch since they have the correct font stamps.
    Paul Abbott
    Early S Member #18
    530.520.5816
    Well, I fabricated tags of the same size as OEM tags but without stamping. I am good with this as a work-around since they look OEM.
    Paul Abbott
    Early S Member #18
    530.520.5816
    I knew you could.
    Feb 2014
    Austin, TX
    Thanks for the Partsklassik link. I've been looking for tags for my Zenith T-V carbs (needed one), and they have these as well.
    '73 RoW 911T (project)
    '77 911S
    Early911SReg #2945
