Results 1 to 10 of 14
Thread: Clonk sound when pulling away?
    Jul 2012
    Kent, UK
    Hi, am getting clonk sound when pulling away, where should I start looking ? Sounds like it is at the back. ItÂ’s on a 68
    Thanks Rich
    Rich
    68 911S
    mbr. 2393
    Start with rear axles and the CV bolts
    Oct 2008
    Burford, ON, Canada
    You probably have a transmission with the simplified differential. If the tips of the bolts holding the output flanges wear, then they can break and cause catastrophic destruction in the diff. You should check that out also. BUT, only remove one bolt at a time.
    https://forums.pelicanparts.com/pors...ferential.html
    Jul 2012
    Kent, UK
    Had the car up in the air, with all external bolts retightened, a hopeful solution, but glonk remains when reloading the car with forward momentum, thinking the diff is cause.
    Rich
    68 911S
    mbr. 2393
    My bet is CV’s are worn out
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Jul 2012
    Kent, UK
    Just lost all power to wheels, awaiting recovery, gearbox engages all gears, but nothing gets to the road. Will post the answers to this post once I know, bring on the speculation, let’s see how gets the diagnosis right.
    Rich
    68 911S
    mbr. 2393
    Jul 2012
    Kent, UK
    Funny thing is I am now sitting in the least environmentally friendly iPhone charger, running a 1968 flat six to keep my phone charged ...
    Jun 2010
    CT US
    blown clutch....
    Jul 2012
    Kent, UK
    With no movement the Speedo would read 30mph in second gear
    Rich
    68 911S
    mbr. 2393
    Quote Originally Posted by Richsmith901 View Post
    It means your pinion shaft is in motion, but there's a disconnect from the pinion gear to the rear wheels.
    It sounds like a CV joint or differential issue.
    Jon B.
    Vista, CA
