Results 1 to 9 of 9
Thread: Source for 90134753700 shock rubber for early steering dampner
    Does anybody out there have a source or if NLA some measurements and material characteristics of 90134753700 the two shock rubbers?? For the early steering dampner? It's illustration 35 in the attached picture
    Tia
    Jk
    Anybody have any idea? Biggest thing is the material as I can whip these up on the lathe easily. The whole assembly is ready to go back in the car. Tia JK
    Dumbass me was referring to illustration #36 and not #35 which is the din 9021 washer
    Bump, anybody who can help? Would like to finish my rack in an authentic way
    When we restored my son's '65 we ended up making our own. I have no idea if they are of authentic size or material. I used a hole saw (1"??) and cut two pieces from a dense rubber mat and then sized them to fit. The material was 1/2" thick Buna-N rubber; D4993 product # 1XZA4; Durometer 70A from Granger.
    I have some left over I can mail you and you can fab your own if you like.
    Glenn
    Granger: https://www.dccyemen.com/productsvie...Stock_no=1XZA4
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    hi Joris
    thats what i used to rebuild it--thr rubber only of course...it came in a bilstein bag so no china crap i assume... can`t remember if it was 100% spot on(doubt) and if i had to trim it on the lathe:
    https://trekfinder.de/Inspektionsset...rt-Nr-1-SUJILD
    br
    franz
    Franz and Glenn, thanks for the pointers. I made some on the lathe from an old shock bushing I had. Now I can finally wrap up the front suspension, thanks a lot!
    Now you are just showing off..............
    Have to do somewhere the home front doesn't much care about pictures of car parts
