Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Hand Brake Cable Strap
    After reinstalling the engine in my '70 911E, I noticed that the hand brake cable interferes with the accelerate linkage. The cable does drop a bit when it is released but I think I've routed the cable incorrectly or it's too short or too long. I looked through the parts catalog and saw there there is supposed to be a cable strap. Does anyone have any pictures that show what the strap is connected to and the correct routing of the cable?
    Chris
    Jun 2012
    London, Ontario, Canada
    Chris, the throttle bellcrank arm is too low for one thing. It should be basically parallel to the ground. Won’t solve all your problems and I too am interested in where the strap goes, but definitely your throttle cable linkages need sorting too.
    Ravi
    Early 911S Registry # 2395
    There are plastic handbrake cable guides which hold the cable up and away from any interference. They are an easy five minute install. With these you should be good as long as the cables are adjusted properly without too much slack. Stoddard has them rt and left.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    I have the plastic guide installed.
    There is also a grey cable suspension strap for 911/912 up to 69 or 70.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    I know I'm missing that. What does it attach to?
    Chris
    If I’m thinking about the same cable suspension strap, my ‘69 has a bracket with a hole in it by one of the rear brake line brackets. I think it is positioned beneath the left rear seat pan. A bolt goes through the strap/hole. Let me know if you need a picture.
    HTH,
    Rick
    Here is the best/quickest photo I have of my 72 with the light gray strap installed with the clutch cable being cradled by it (look just above the ball socket). Not fun to install...each end of the strap has a grommet and when looped together a small (6mm) bolt secures it to the transmission.
    Thanks Mac73S. That is what I was looking for. Hope my car still has the tab attached to the rear seat bucket.
    Chris
    Quote Originally Posted by chris belyea View Post
    Chris
    You're most welcome, but to clarify, the seat bucket tab you mention is for securing the left side emergency brake cable, not the clutch cable...that 'loop' is just north (on the photo) above the bell crank ball socket.
