Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: Hand Brake Cable Strap
  1. #31
    Oct 2010
    Southern Ca.
    Nice ! I said it would be a little manual dexterity test .
  2. #32
    Here is my hand brake cable strap. My recollection is the brake strap was longer than the clutch cable strap. Old part numbers are different for clutch and brake suspension straps. Clutch, 999 706 009 80. Brake, 999 706 012 80. G
  3. #33
    Jun 2012
    London, Ontario, Canada
    Gordon,
    Yes, the brake one is NLA but the clutch one is still available. Clutch one is 80 mm and I believe is the shorter of the two. But shorter works as a default and keeps the brake cable and the flapper box cable off the throttle bell crank. So I imagine that's why they obsoleted the longer one.
    It still amazes me that obscure parts like that L bracket and the grey strap are still available new from Porsche. The L bracket was NLA for a long time, but is back in production and stocked in Porsche's US and Canadian distribution centres.
    Early 911S Registry # 2395
  4. #34
    grey straps for cables
  5. #35
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Quote Originally Posted by 356hunter View Post
    www.autoatlanta.com also carries these straps for $2.17 apiece. Their part # G99970600980.
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
  6. #36
    Jun 2012
    Auto atlanta carries the one Porsche still sells. That's the 80 mm clutch one. Available at your friendly dealer, though the Auto Atlanta price is about 1/3 the normal dealer price.
    Good find on the Stoddard catalog. None of those are technically the right length for the brake I believe although the 165 mm one may be close enough. The short 80 mm one keeps the brake and flapper box cable well off the throttle bell crank, so that's probably all one needs to be safe and not have your throttle hang up because the bell crank caught those cables.
  7. #37
    Apr 2003
    New Jersey
    Here’s a photo of the $2.17 strap from Auto Atlanta...100mm total length, 80mm from bolt hole to bolt hole:
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
  8. #38
    Jun 2012
    That’s the same size as Porsche sells. 80 mm eyelet to eyelet. So if you want longer, Stoddard or make your own.
