Page 6 of 23 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 224
Thread: 71 Gemini Blue finally getting close to done...
  1. #51
    Dec 2013
    Connecticut/Florida
    1971 911S Coupe - Gemini Blue
  2. #52
    Oct 2010
    Southern Ca.
    The front oil cooler hard lines received undercoating and black paint like the wheel well at the factory . Also , the fenders were on the car when it was painted . It has to be hard posting pictures for everyone to critique , but good luck .
  3. #53
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by Richy View Post
    Thanks...and Agreed....I may still paint them black..And the fenders were painted on the car.
  4. #54
    Dec 2013
    Connecticut/Florida
    ok, so I got the kinks out and I am painting the lines black....Started to mock up the rear oil tank and connections...
  5. #55
    Apr 2011
    N.Calif., south of SF
    Yes, they're upside down. The large diameter of the bushing is towards the mounting hole, same for the bushing underneath. Otherwise looks good.
    Thank you Ed. Never knew that.
    Simonjjb- You are doing a great job. Did that on the '73. Thinking through it all and asking lots of questions the way to go.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  6. #56
    Member cairo94507's Avatar
    Aug 2011
    San Ramon Valley, CA
    Absolutely stunning car and work. That will be one to be proud of no doubt. Thanks for posting so we can all enjoy the build.
  7. #57
    Dec 2013
    Connecticut/Florida
    It always amazes me how much longer it takes to reassemble a car vs taking it apart.....the long, somewhat tedious, But critical wiring process continues...
  8. #58
    Dec 2013
    Connecticut/Florida
    Wires and more wires...
  9. #59
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    I'm curious about what type of sound deadening you will choose?
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
  10. #60
    Is it possible, that the shocks touch the cross member? I have the same issue with mine....
    Quote Originally Posted by Simonjjb View Post
    Attachment 536075
    Still have to run the battery cable properly
