Results 1 to 2 of 2
Thread: Trunk seal installation question...
    I received PORSCHE'S latest trunk seal supersession (suffix is '04') and it is indeed improved oven previous versions...fits very, very nice. I don't recall if the fresh air cowl grill is to be removed first, the seal fitted into the channel and then the lower edge of the grill secures OVER the gasket - or whether the gaskets just sits on top of the grill at the bottom. Seems I've done it both ways in the past...curious what the text book answer is. Thank you.
    Oct 2010
    Southern Ca.
    Gasket sits on top of the grill bottom , no question !
