Results 1 to 7 of 7
Thread: swb oil lines - cooler - which to use? what to do?
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    as I am further upgrading my 65, the next step would be the preparation for the oil lines and to get an oil cooler in the front.
    There are so many discussions, which parts to use on a 65, which oil coolers, which lines...
    The one saying, nope, not usable
    for a swb, the other, nope, there had not been a thermostat behind the oiltank etc.
    The next, cut down some G model oil lines and make them fit.....
    Well, I am not the expert on oil lines, so please, I do need your advice on this issue.
    br
    stay safe&healthy
    haul
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    On my 67 I used a combination of 69-71 S tank mounted thermostat, custom made lines and 74 style rocker panel lines, and a mid-eighties 911 Carrera oil cooler.
    Aug 2010
    I have Elephant Racing lines and thermostat on my 67. I had one of their Carrera type oil coolers up front. I've since taken it off and gone to duel triple trombones. Overkill but a fun project.
    Sep 2009
    COPENHAGEN, DENMARK
    Hi Haul
    I have reproduced the complete S oil filter consol, thermostat, and the 4 oil lines for 69-71
    the oil filter console is ready on stock 449€
    https://www.early911sregistry.org/fo...ighlight=marek
    the thermostat follows in a few weeks 479€
    in September I have the full kit of oil lines / tubes
    that would be priced 1495 € as a complete set ( incl the console and thermostat )
    I am thinking of making the oil lines for swb specific... but I have to see how sales go on the above
    shipping to US can be a problem ( the oil lines )
    I also have the S oil tanks if so
    Marek
    Aug 2010
    Very cool parts.
    That oil filter/ thermostat housing is in short supply, glad to see you're making them. Do you happen to make the 69-71 oil tank with increased capacity and baffled?
    Sep 2009
    COPENHAGEN, DENMARK
    sorry we only made the tanks as original
    we made some 72 oil tanks larger to ST specs some years ago
    the 65-71 oiltank is hard to make larger .. but will maybe look into it
