Thread: Key Ignition/Tumbler
    Junior Member trlin's Avatar
    Dec 2018
    NH
    Hi All,
    Yesterday I put the key in my '69 ignition and the key turned hard to the right and then didn't have any spring bounce back to the left. I pulled the key out and apparently it got bent somehow prior to going in the ignition. The bent key apparently did some damage in the tumbler/ignition. Anyone know what the best place for a fix may be? Locksmith? P-car mechanic? I'm afraid if I keep using my spare straight key that it may fail or break off in the ignition/tumbler which is damaged.
    Any suggestions on which way to go would be greatly appreciated, thank you very much!
    -T
    - 1969 911S
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    The last time the key got stuck in the ignition lock on my 1969 911 I removed the lock cylinder (easy to do) and brought the whole unit to the local locksmith...he fixed it in minutes for $15.
    There’s nothing special or exotic about our ignition lock.
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Dec 2018
    NH
    Thanks Alan, greatly appreciated!
    - 1969 911S
