Results 1 to 10 of 11
Thread: Are these Compatible- Bat Wing & 380 ?
    Guys
    No experience with steering wheels and related components.
    Will these assemble and be operational, must Be some Additional components to make the horn function via the center button and the wings ?
    Interested in comments and input .
    Also is there a center hub & button ( without the wings ) that is compatible?
    Thanks for assistance
    FrankName:  7551CBB1-384C-4184-B614-4900C48B8797.jpg
Size:  145.3 KBName:  57F95072-2540-4DF7-A83B-844F5F52248B.jpg
Size:  90.8 KBName:  57F95072-2540-4DF7-A83B-844F5F52248B.jpg
Size:  90.8 KBName:  35DC70AD-36AA-4E3B-8DF6-F88F3007246F.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Subscribed.
    Apr 2004
    35,000 ft
    You are missing a rubber bushing/buffer on the horn button and probably the spring loaded contact.
    You absolutely can swap a standard hockey puck horn button in place if the one you have with the wings.
    It looks like you're missing the clamp plate that is rivited to wheel hub that the bat wing clamps onto.
    Jul 2011
    Chicago Area
    Hard to read the picture but wheel looks like it is dated 10/75 so you will need to drill 2 threaded holes on the back of the hub to connect the correct 911 cancel ring. Spring loaded contact goes through that circle hole to the right of the VDM logo.
    Mike Fitton # 2071
    2018 911S Carrera White
    Thanks Guys ....Mike yes 10/75, next comments requested
    Seems the mods needed make a hockey puck type easier ?
    Better to sell the bat wing( what year/type will this fit ) Also will need parts for the hockey puck..
    Are these readily available or after market ?
    Any photos
    Thanks again for assistance
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    The way I see it that bat wing isn’t intended to be paired with the late 380 wheel.
    Appreciate all input ...
    Thanks again
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    use a hockey puck.
    bat wing on 380mm sw looks strange
