Results 1 to 7 of 7
Thread: the engines only a little bit broken...
    Aug 2017
    el sobrante ca.
    i don't have access to the motor. no real knowledge of motor history ,only anecdotal evidence it was a race car... Question is.... "Turns in each direction 1or2 centimeters."
    I am not a mechanic, so my guess is just that, a guess.... the crank shaft should be ok in its journals, and damage would likely be higher up or possible rod journal???/.
    I am asking because i may have to buy this motor, blind.... From !-5 what are the odds the cases are salvageable? 1 being good odds 5 being not good.
    bob. reg#3596
    May 2014
    South East USA
    turning some, should be much better than frozen.
    a piston is probably hitting a valve.
    other things i think it could be, intermediate gear problem, chain has jumped teeth. or a broken rod.
    but, is the tranny connected...and the car is in gear? not neutral...i can imagine, in my mind, and engine turning a centimeter, in gear. back and forth.
    and if the tranny is connected...it could be a tranny problem or a clutch problem.
    and one more thing. my car, in gear, parking brake on, the engine will rotate 1+ cm.
    Aug 2017
    el sobrante ca.
    Thanks Scott A ... The engine is separated from the trans.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by bob joyce View Post
    bob. reg#3596
    Buy it assuming that nothing is any good. You won't be disappointed
    Aug 2017
    el sobrante ca.
    Thanks Jim A very wise philosophical approach ... I hope i can achieve that position...
    Oct 2010
    Southern Ca.
    Good advice Jim , and you have more experience than most or all of us .
    Jun 2012
    London, Ontario, Canada
    We really need a laughing/crying emoji
    Early 911S Registry # 2395
