Thread: How to move a 911 Tub?
    Any suggestions on a clever way to roll a 930 Tub over concrete and onto a trailer? (No axles or wheels)
    Quote Originally Posted by usaspeedster View Post
    If you have to move it a distance or onto a truck I can send you plans for our carts we use to get cars with no suspension onto a car carrier.
    ---Adam
    Check out Unobtanium-Inc.com
    New blog posts all the time!
    I've seen a few methods. One was using moving dollys from Harbor Freight (1000lb capacity each) and using ratcheting yellow "tie down" strapping them under the chassis. Get the ones with the tallest wheels, or swap the wheel type out for a "taller" set.
    I've seen it done exactly as Eric said.....
    Cheers and good luck,
    cm
    Jul 2008
    South Florida
    Moved a 2002 shell many years ago with what we had on hand: some rope, a pallet and a set of 6" industrial casters. We got it onto the pallet with a pair of floor jacks.
    I've seen Eric's method too. Cheap and easy. And afterwards, you'll be amazed at all of the uses those dollies will come in handy for!
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    You can also do a smaller cart like this one that we use. The ones in the other pic we use for cross country car carriers, but just on a normal trailer you don't need the big width or the heavy duty wheels.
    ---Adam
    Jun 2012
    London, Ontario, Canada
    The tub is only 650 lbs. Moving dollies work fine. Or if you have some appropriately spaced holes in the pan, put 4 heavy duty casters with threaded stems through them, add some nuts and washers or backing plates and hey presto, you are done. Done this with some other old cars, though not an early 911. You can make a custom dolly with these type of casters and 2x4s in under and hour as another option.
    Early 911S Registry # 2395
