Thread: Replacement Oil Line Elbows
    May 2006
    CT
    I am getting ready to install the engine in my '70E restoration project and am about to put together the cooler to tank oil line. I have beautiful collars from Jim Tidwell but I would like to replace the elbows as the fastening nuts are pretty beat up and corroded. Anyone know of a source for the elbows or a way to replace just the nuts?
    I know I could just replace the entire line with a new one but I want to stick with the original style fittings.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Tom:
    Did you check with Brad Davis on this forum?
    Good luck,
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Hi Tom,
    Are 90* tube portions aluminum or steel? If they are steel I can remove the nipple, put on new nuts (exact same as are on there now) then silver solder the nipples back on. If aluminum there is a bit of a different approach. I am also happy to help you with the proper wrap cured hose.
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
