Results 1 to 10 of 11
Thread: throttle lag 3K to 4K rpm 72 MFI
    Jun 2011
    Bellingham, WA
    I am not sure if lag is the correct word, but as I am accelerating, as soon as I reach 3000 rpm, the engine falls flat until I pass 4000 than it picks up nicely and away we go.
    It is a stock 72 911 T with MFI. new injectors and rebuilt MFI pump & fuel pump, new plugs & wires
    It has the original distributor with only cap, rotor and oil wick being oiled
    any ideas as to where I should look next?
    Aug 2017
    el sobrante ca.
    there are people on this forum with much more knowledge and experience than me... 30 years ago i had this problem, The mechanic who worked for red mcclintoch in Berkley, and was incredibly good said that this problem normally, was do to , the intake stacks and butter fly's and linkage .
    Jun 2012
    London, Ontario, Canada
    Was the right space cam used when the MFI pump was rebuilt? S space cams in 72 and 73 had a noticable flat spot (lean) in that range, likely for emissions reasons. If everything is new and you know your vacuum advance is working properly, you really need an air-fuel-ratio meter to know what’s going on.
    Early 911S Registry # 2395
    Aug 2017
    el sobrante ca.
    yep ... that's how red fixed mine ... one of those big air thingys and linkage adjustment ...
    Nov 2004
    Alberta, Canada
    Ignition advance working OK?
    Sep 2018
    Netherlands
    It could be anything. You need to go through CMA from start to finish:
    http://early911nzdownloads.yolasite....ure_adjust.pdf
    1970 2.2S Elfenbeinweiss
    2002 996 TT Midnight Blue
    Member #3833
    Normally a rebuilt MFI pump will need some adjustment after installation. Was this a shop install or self done? Were any linkage rod adjustments made?
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    If the pump was calibrated back to factory specs and you are running fuel with 10% ethanol, you will require about a 8% increase in fuel output.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Quote Originally Posted by BURN-BROS View Post
    Interesting to learn.
    Peter Kane
    '72 911S Targa
    Sep 2003
    Camarillo, Ca.
    If the throttle bodies were rebuilt, they were most likely had the bores cleaned up and larger throttle plates installed. This can affect part load and cruise so adjustment may need to be done in those areas.
    Aaron Burnham
    Burnham Performance
    805-240-6931
