Results 1 to 2 of 2
Thread: ring & pinion change for a '66
    My '66 911 is a restored to stock car except the engine is built up for about 180-190 HP. I'm using the original 901 transmission, but using the original gear ratios. Engine turns 4,500 rpm at 80 MPH. What do you suggest for a ring & pinion swap ?
    Oct 2008
    Burford, ON, Canada
    I think that is a difficult thing to do unless someone makes a different ratio than the factory supplied. Much easier to change the gears. The 914 used the longest ratios despite having the least power.
