Thread: Spacer for Bilstein insert in Boge strut
    Senior Member Jon1966's Avatar
    Feb 2014
    Herts, UK
    Having installed Bilstein inserts into my Boge struts on our 66 SWB there is a “clonk” over small bumps/potholes. I read in various places (e.g. https://www.912bbs.org/forum/threads...inserts.42950/ ) that a spacer may be needed to stop this. Strange that its only on the passenger side, but I guess there could be a difference between the struts (this was a rally car).
    Anyone know where to get one or what the dimensions would be to get one made up?
    I see koni inserts listed on Stoddard come with a spacer...
    1966 911
    May 2009
    Wellington, New Zealand
    i cut out a disc of 5mm aluminium with a hole saw. "carefully formed" (hammer and a block of wood) to match the shape of the bottom of the shock. It was enough to allow the strut tube nut to hold the insert tight. Im sure the "proper" way is to find/make a tube spacer to fit at the top of the strut tube.
    Nov 2010
    North Carolina
    Here is an original Bilstein insert for an SWB Boge strut. You would want to make the outside diameter a little smaller as this is a tight fit and once you get it in there it is nearly impossible to remove.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    No. P36-0111 did not exist anymore. But we can deliver P36-0112 (new part no. 34-001127) which is similar to P36-0111 but only a little bit shorter. To fit the cars till ´68 you have to use a flat washer witch you have to put in the bottom of the tube in order to reach similar length to fit it in correct position. This tricky solution in known by all Porsche specialists
    Best Regards / Mit freundlichen Grüßen,
    XXXX XXXX
    Aftermarket Sales Manager
    ThyssenKrupp Bilstein Tuning GmbH
    Unit 3, Swannington Road
    Broughton Astley
    LE9 6TU
    England
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
